44 massey wide front
jim
08-16-2003 18:15:12
i am looking for input from anyone who has installed a mh wide front on a 44 row crop. is the gear the same? thanks jim
off the land
08-16-2003 19:35:48
 Re: 44 massey wide front in reply to jim, 08-16-2003 18:15:12
If referring to the sector "gear", like almost all
parts, except the front wheels and housing for the
steering box, everything it different. The sector gear is splined on the WFE, for tie rods, even to have a machine shop modify two, for one, is a job.
The worm shaft is reversed, in cut direction, from
the narrow front & standard models. The early tube
style, in '48, was flawed with weak support cast
housing. In '49, this support was changed. Lots of
wear parts on WFE's, expensive rebuild. Good luck.
brian
08-16-2003 19:19:25
I just went the other way from a wide front to a narrow and I can tell you that some are the same steering gear and some are different. One I had has an angled worm gear and one had a straight cut worm gear. Take the top off the gear boxes and if they have the same cut gear it will work because I ended up using the same gear box on both front ends and it worked fine.
