hyl lift bounces up and down
chuck
08-15-2003 19:49:13
just fixed " i thoughtt" the lift on the 135..filter gone and full on trash... lift raises
good, but seems to 'Bounce up and down"
did i screw up something or need to adjust something ???
Big Dean
08-15-2003 23:09:55
 Re: hyl lift bounces up and down in reply to chuck, 08-15-2003 19:49:13
If it is bouncing after it reach the top it is cause by a leak in the system & as the lift drops the linkage is causing it to correct it's self back to the original setting. If it is bounces while it is lifting it has a cylinder in the pump missing either caused by an intake or discharge valve leaking or broken ring on one of the piston. Sometimes a loose master control spring will cause them to bounce when they are raising
