MF35 PTO Shaft needle bearing
Steve Cushman
08-15-2003 15:01:08
Can anyone tell me how to remove the front bearing on the MF35 PTO shaft? Shaft is out, and I can see the bearing retainer up in the bore. Does it need to be pulled backward, driven out from the front, or does it unscrew? I've tried all three methods -gently- and nothing is moving yet. The needle bearing is bad and needs changing. Anybody done this?
Thanks if you can help.
Steve Cushman
08-18-2003 17:25:37
 Re: MF35 PTO Shaft needle bearing in reply to Steve Cushman, 08-15-2003 15:01:08
I got the bearing out ok. Just needed a larger puller.
