Massey Harris 44 row crop radiator
Tim Jones
08-15-2003 10:09:44
I am looking for various part's for a MH 44 row crop . I need a radiator and a set of fenders. I am sure that I will need more items as I start working on the tractor . Will a MH30 radiator fit?. I have found a few part's but I'm not familur with massey harris and I don't know very many places to look for the parts I might need.
Massey player
08-24-2003 04:16:27
 Re: Massey Harris 44 row crop radiator in reply to Tim Jones, 08-15-2003 10:09:44
Tim, I can help you with a radiator, as well as many other Massey 44 parts.
SHANNON
08-15-2003 20:00:29
THERES RADIATOR AND FENDERS FOR SALE AT EBAY... WWW.EBAY.COM... I THINK THE TIME IS ALMOST UP.. BE SURE THEY ARE THE RIGHT ONES FOR UR MH 44 I THINK THEY ARE... IF U WANT TO HAVE THOSE RIGHT AWAY.. ITS AT EBAY... JUST SAW THEM FEW HOURS AGO ... HOPE THATS WHAT U ARE LOOKING FOR...
SHANNON
STEVEN H
08-15-2003 13:53:56
also if you are going to need engone parts, let me know as i have a few from a motor that i am going to be partsing out. the crank is not good in its present state and would need to be cut.
off the land
08-15-2003 10:52:42
Serial numbers help, to include. Just scrolled down to find you older post , a 4 cylinder, 44,
correct? With live clutch, must be a '50-'53?
No, on the 30 radiator, that's about...12 qts.
You need about 23 qts, common item on 44's,
but not 44-6 flathead models. If you have the upper & lower tanks, a core can be replaced. If
the 30 had decent RC fenders, a fit on these.
Good luck.
Tim Jones
08-15-2003 13:18:56
 Re: Re: Massey Harris 44 row crop radiator in reply to off the land, 08-15-2003 10:52:42
So I can't use a 33 radiator?. thanks for telling me. are there any 44 radiator's out there?. The fender's are off of a wide front 30.
it isn't a standard 30 . does that make any differance?. they are the clam shell type with no fender ledge. you can see them on e-bay.
STEVEN H
08-15-2003 13:51:21
 Re: Re: Re: Massey Harris 44 row crop radiator in reply to Tim Jones, 08-15-2003 13:18:56
the idems from the tracotor being parts out is a 30, most parts will not fit, if the rad is part of what is being partsed out that it is off a 30 and will not fit, i think that a 33 will fit. but you have listed both a 30 and a 33. so which one is it? note i could be wrong on the fiting of the 33 and will check latter on. off the land will be the one to truest on fits though.
off the land
08-15-2003 17:05:51
 Re: Re: Re: Re: Massey Harris 44 row crop radiator in reply to STEVEN H, 08-15-2003 13:51:21
44RC's ran with a 23 quart radiator. 44Standards
ran a 22 quart radiator. All 33's had an 18 quart
radiator. The 33 will not be a dead on 'go'. You
are circulating under capacity. On the Parade tour
you would get by, but what of road travel, any
work? Why risk overheating? The 22 quart should be
'adequate', but 23 quart from a 44RC is common. On
Y.T. Classifieds, post a 'Wanted' in Massey section, for a 44RC radiator. Do you need the support frame? 30/44/101jr/senior RC fenders match
(38" rims).Confirm no rot/breaks/damage/shipping.
Good luck.
