MF50 steering
Dave in Oklahom
08-12-2003 07:00:55
My MF50 turns a lot farther to the left than it does to the right. It has power steering that's not working right now, but it turned the same way before the power went out. Any ideas?
HappyKansan
08-12-2003 14:54:36
 Re: MF50 steering in reply to Dave in Oklahoma, 08-12-2003 07:00:55
My MF65--same thing---no pump in fronts? Could the tie rods just be adjusted wrong?
Big Dean
08-12-2003 08:51:12
By chance do you have a front pump for a loader on this tractor?
Dave in Oklahoma
08-14-2003 16:29:28
 Re: Re: MF50 steering in reply to Big Dean , 08-12-2003 08:51:12
No Big Dean, there's no front pump for a loader on it. Just the power steering which probably needs to have the plunger rebuilt. Power worked until about two weeks ago and just quite while I was mowing. But, like I said, it turned the same way even when the power was working.
Big Dean
08-15-2003 07:22:21
 Re: Re: Re: MF50 steering in reply to Dave in Oklahoma, 08-14-2003 16:29:28
Check the tie rod to see if both are set in the same notch where they slide & where the tie rod end screws into the tube is set close to the same on both ends. If one is screwed way in and the other is screwed way out that will cause the problem you are having. Check the pitman arm to shaft to see if the timing mark are lined up I think the MF50 has time marks there & there are different lengths of drag links that go from the pitman arm to the steering arm behind the grill that will fit on the MF50 but some them are to long and will make the steering do like your is doing.
Dave in Oklahoma
08-15-2003 10:07:07
 Re: Re: Re: Re: MF50 steering in reply to Big Dean, 08-15-2003 07:22:21
Thanks, Big Dean. The tie rods are not equal. I'll fix it this weekend and check those timing marks, too. Do you know if there's a rebuild kit for that plunger behind the grill? I think that's the problem with the power steering. I know the ps pumps are a little expensive but easy to find but I think it's OK. You deserve a medal!
Big Dean
08-15-2003 13:18:57
 Re: Re: Re: Re: Re: MF50 steering in reply to Dave in Oklahoma, 08-15-2003 10:07:07
Dave I have been retired for over 7 years but the last I knew you could get two kits for there one is for the complete cylinder & selector valve the other one is for just the selector valve.
