MF 165 Front End
Tom
08-10-2003 18:29:57
I have recently purchased a 1965 MF 165 and when traveling down the road in high gear the front wheels wobble in and out very rapidly i changed the tie rod ends but that did not help at all any input would be appreciated.
Thanks Tom
William Simmons
08-13-2003 14:32:34
 Re: MF 165 Front End in reply to Tom, 08-10-2003 18:29:57
I have one 2 and front and rear do it . i went to the dealer and they said they have always done that!!
Tom
08-14-2003 04:16:48
 Re: Re: MF 165 Front End in reply to William Simmons, 08-13-2003 14:32:34
You need to find a new dealer. If the tractor is in good shape it will not do that.
Big Dean
08-10-2003 22:14:35
Try toeing the front wheels in a little in front that will usually take care of that problem They should be a 1/4 inch closer in front than in they are in the back.
HappyKansan
08-10-2003 19:46:44
Are the rims bent, wheel bearings really loose, tires out of whack? Jack the front end up and spin the tires by hand and see what happens...just some ideas....
Roy in UK
08-10-2003 23:29:26
 Re: Re: MF 165 Front End in reply to HappyKansan, 08-10-2003 19:46:44
Not forgetting king pin bushes.. or wheel nuts
Steve
08-11-2003 19:30:18
 Re: Re: Re: MF 165 Front End in reply to Roy in UK, 08-10-2003 23:29:26
i have one that does the same thing, got some friends who have the same trouble with their 165 also. need to rebushing the front axle at the center pivot and the steering arm under the front center. May need to replace the center pin along with bushing. Price tag??? have no idea
