massey 35
cpdavies
08-10-2003 01:11:19
I am a complete novice at tractors and have bought a massey 35 (1962) it seems to lack power and is over heating and the oil pressure is low what can i do ?
SassyMassey
08-10-2003 19:55:51
 Re: massey 35 in reply to cpdavies, 08-10-2003 01:11:19
I would do the usual tune up....plugs, points, condensor, plug wires, distributor cap, rotor, flush radiator, check timing, then see if that helps things out.
SassyMassey
08-10-2003 19:58:06
 Re: Re: massey 35 in reply to SassyMassey, 08-10-2003 19:55:51
Don't forget to change the oil and filter...you may also want to do a compression check to test the integrity of the engine.
