MF 65 PTO
HappyKansan
08-08-2003 09:54:48
Can someone explain the different positions of the PTO shift lever on a MF65. What is "Ground PTO"(I think that's what it says, now that I am in front of the computer I can't remeber...anyway I know there is more than one setting) I noticed in this setting the PTO only turns when the tractor moves and is regulated by the speed of the tractor. What is the purpose of this setting? Is it for some sort of implement that must speed up in order to keep up with the tractor??? Thanks
HappyKansan
08-08-2003 12:30:44
 Re: MF 65 PTO in reply to HappyKansan, 08-08-2003 09:54:48
Thanks for the clarification!
Big Dean
08-08-2003 12:21:56
In ground speed the PTO output shaft is turned by a gear on the differential pinion shaft & a gear on the PTO shift collar. When you put it in ground speed the two gear mesh. Ground speed was used for implements that need to vary in speed with the ground speed of the tractor. The engine speed is engaged by the shift collar sliding up on the rear shaft of the three point pump & the PTO output shaft varys in speed wiht the engine speed.
