Pulling piston sleeves on TO-30
Tom
08-05-2003 02:10:41
Can I pull piston sleeves on my TO-30 using common garage tools or do I need to buy, rent or make a special tool. Any assistance would be appreciated.
ST in Ca
08-09-2003 17:58:52
 Re: Pulling piston sleeves on TO-30 in reply to Tom, 08-05-2003 02:10:41
Yes you can, use a block of wood and a hammer and they pop out. Turn the engine block up side down and put a block of wood at the bottom of the sleeves and with the hammer tap them out. The new sleeves come with a new O-ring place the new sleeves in and if they don't go all the way down when you bolt the head back on the sleeves will be set by the head. If you don't have a good shop Manual you should get one, and go by there instructions. Working on these old tractors can be a lot of fun. Good luck
