925 Mo/Co bearing replacement
rob
08-03-2003 18:18:13
I need to replace the bearing on the lower roller(gear box side), my question is about the pully removal(the one with the pitman pin on it) it appears to be threaded onto the shaft. Is that correct? any suggestions on the removal? Thanks.
marlowe
08-04-2003 09:57:44
 Re: 925 Mo/Co bearing replacement in reply to rob, 08-03-2003 18:18:13
yes it is threaded and it is the opisit that it turns.there is a set screw that you lossen .if i recall snub the pull and at the other end of the roller there is a place for a big pipe wrench
