Hydrostatic Power Steering Problem : MF40 Ind
Greg
08-03-2003 16:55:02
I'm looking for some info on identifying a power steering problem on a MF40 Ind. When the steering wheel is turned slowly, the steering cylinders respond, but with fast movement, there is little or no response from the system. The resistance felt on the steering wheel is not much different, just that the wheels don't change direction!
Where do I start? Can I check the system pressure? What should it be on full lock? Should I focus on the pump ( a Barnes type)or the control valve behind the steering wheel? Are there rebuild kits available for the pump?
Greg
