MF130 won't start!
John Luty
08-03-2003 16:03:08
Does anyone have any suggestions....my MF130 won't start. The starter turns, and engages with the flywheel, but there is just a whirring sound from the starter and nothing else. I'm rather baffled by this, as I would have thought that if the starter engaged with the flywheel but then wouldn't turn it, then the starter would have cut out, but it doesn't!
thanks.
John Luty
08-05-2003 03:00:19
 Re: MF130 won't start! in reply to John Luty, 08-03-2003 16:03:08
Thanks for the info.....can this be repaired or do I need another starter motor? It is a bit baffling to a layman ,since I can see the starter motor shaft spinning and engaging yet nothing happening!
regards,
John Luty
Big Dean
08-06-2003 11:16:16
 Re: Re: MF130 won't start! in reply to John Luty, 08-05-2003 03:00:19
It can be replaced but the nose of the starter has to be removed to install a new one.
Big Dean
08-04-2003 22:57:45
John that is caused by a bad starter drive most people call them a starter Bendex.
