Difference between a 162163 Continental
justin
08-02-2003 08:53:20
Whats the difference between the two engines? Both are red seals.
Alberta Mike
08-02-2003 11:28:01
 Re: Difference between a 162163 Continental in reply to justin, 08-02-2003 08:53:20
I have a Continental factory engine manual here for their flathead engines and the only difference in the spec pages that I can see is the specifications with regards to the pistons and piston rings. Specs relating to ring groove width and maximum wear limits on the pistons are different, so are the ring width, side clearance and wear limits on the rings themselves. Other than that, all other specs are identical. I think the 163 was more of an industrial engine but it couldn't be too much different other than the things I mentioned. Cylinder diameter (block bore) on both is identical.
Alberta Mike
08-02-2003 11:34:20
 Re: Re: Difference between a 162163 Continental in reply to Alberta Mike, 08-02-2003 11:28:01
Just noted some other differences too. Differences in the main bearing specs as well as the length of the piston pins too. Also some differences with the connecting rod bearings. It seems that the 163's were a a bit beefier (but not too much).
