FRIST TIME TO DO THIS........
SHANNON
07-31-2003 23:27:33
theres tractor pulling at end of august... this is a frist time im going to use my mh 44 in pulling contest... i have no idea about anything but would like to do that... any tips or advices that i need to know?? heres what i have, 4 cylinder h260 it might be 277.. not sure.. i have 18.4 x 38 tires with water ballast in tires.. alot of weight and mounted on my mh 44.. will i lose alot of power or not? it seemed not affected at all... what gears should i put in 1st , 2nd or 3rd??? im not sure what class i will be in.. have to go weight it then they ll tell me which class... its gonna be fun!
thanks shannon
off the land
08-01-2003 10:26:18
 Re: FRIST TIME TO DO THIS........ in reply to SHANNON , 07-31-2003 23:27:33
Unless your going to a mud pull, forget 18.4x38's,
a 'stock' 260 is dead in first, with that rubber.
Weight will not save you, nether will traction,
your forgetting to take some power with you. This
ratio might pull through with 80 hp. Perhaps 14.9x38's in first, 13.6x38's,pulling stock...
Your drawbar needs a hole drilled, to push it
forward: add pull weight to the rears. Lots of
techniques to 'improve' your stock of 'stock'.
Good luck in a bias color war.
SHANNON
08-01-2003 21:19:25
 Re: Re: FRIST TIME TO DO THIS........ in reply to off the land, 08-01-2003 10:26:18
sooo its not gonna be able to pull 4000 class? i thought it might just barely enough power to keep it going... i have like 6 ft brush hog with that big tires on it... it was working hard but did ok... that grass was like around 5 ft thick and bushy... so i was thinking it might be just enough to keep the tires moving if it stops... you have seen those with that tires like mine that didnt make it pulling? either 260 or 277 gas , it wont do the job??? i know its a big difference between that 14.9 and 18.4 tires.. about a foot bigger... i was hoping it wouldnt affect too much... might have to put smaller tires , you think? thanks for advices!
shannon
