Low oil pressure
Phil Leithold
03-27-1999 07:09:18
My to-35 runs real well but the oil pressure is about 60 when i first start it up but drops to below 20 after it is worked for a while and less when it is at a idle. Do I have to worry about it or is that enough pressure?
Randy Dellinger
03-29-1999 18:11:39
 Re: low oil pressure in reply to Phil Leithold, 03-27-1999 07:09:18
Phil, My TO-30 runs at 20-25 psi at all times as the shop manual recommends . I have never seen it surge upward at start up as yours does. So, the 20 psi you see after warm up does not sound unusual. Anything under 15 psi is not good. You might want to order a shop manual for your particular tractor, however, to verify exact psi.
