MF135
Louis
02-19-2000 00:08:44
I have a MF-135,Diesel. I have taken off the generator & voltage regulator, and want to replace with an alternator. Anyone done this? Any tips? Thanks.
Gerald J.
02-19-2000 01:24:32
 Re: MF135 in reply to Louis, 02-19-2000 00:08:44
You need an alternator and its correct regulator. One wire alternators are very handy that way.
You need an alternator pulley to match the width and V angle of the tractor and that probably is 2/3 the diameter of the generator pulley, maybe half to raise the speed of the alternator. Then after you work up the new mount, you connect the wire that used to be on the battery terminal of the regulator to the output terminal of the one wire alternator.
Delco alternators that I have tested for self exciting (like the one wire regulator) needed 1500 RPM to start. The generator wasn't turned that fast at engine idle.
Gerald J.
