MF 40 Auxiliary pump
Hugo
07-27-2003 07:34:42
Hi, I have a MF40 tractor with a MF30B loader, the pump is making noise as if the spline is slipping on the tractor shaft.
I would like to know what is the flow rate and RPM of the pump to select another one.
Thanks.
Hugo
Phill
07-27-2003 16:42:40
 Re: MF 40 Auxiliary pump in reply to Hugo, 07-27-2003 07:34:42
Hugo, do you have any color photos of your F-40 ?
if so can you forward some to me. I have one I'm getting ready to restore.
Thanks
Phillip McCarthey
Tuttle, OK
Big Dean
07-27-2003 12:12:41
Your pump is probably OK it is usually the splines in the shaft coupler that wear out. The pump shaft is very hard but the coupler is not. the best I remember the MF30B pump was rated at 24 GPM. but it has been a while I could be wrong.
