MF-65 Hydraulic Pump Woes
Happykansan
07-24-2003 08:28:59
I would like to install an internal hydraulic pump on my MF-65 to run my loader, etc. Right now I am using a PTO driven pump and it is a pain because in order to use my Bush Hog, I have to yank the pump and tie it up out of the way. Can anyone give me tips on how to go about this. Is it quite a challenge to install and are the parts readily available? If so what parts are required? Any info on this topic would be helpful. Thanks
Big Dean
07-25-2003 20:16:27
 Re: MF-65 Hydraulic Pump Woes in reply to Happykansan, 07-24-2003 08:28:59
Auxiliary pump new about $400 to $500 Mounting plates with gear train to mount & run the pump $350 to $400 new. You need an access plate drilled to except fitting to the outside all the fittings and lines to go from the pump to the outside. I am guessing new this would cost somewhere from $100 to $150. From a salvage probably half that. The tractor has to be split between the transmission & the rear housing to install this. For more Information on adding the factory auxiliary hydraulics Email me
