model 81 Distributer ?
Mark W
07-22-2003 20:57:43
Is this correct, sitting on the seat of the tractor is #1 on the distributer at the upper left. and then going counter clockwise lower left #2 ,lower right #3 and upper right #4. Thanks for your help. Mark
Alberta Mike
07-23-2003 03:56:00
 Re: model 81 Distributer ? in reply to Mark W, 07-22-2003 20:57:43
On a distributor engine, it doesn't really matter which terminal is number one, as long as that particular terminal is timed to fire at for the #1 cylinder of the engine when it's piston is at top dead center of it's compression stroke. Then, after that the order must correspond to the firing order of the engine design. That Continental flathead in your tractor has a firing order of 1-3-4-2 (I can't remember in which direction this is inside the distributor but the rotation of the distributors rotor when the engine is rotated in it's normal direction will tell you that).
