massey 44 1st gear
Doug
07-22-2003 19:48:36
hi i have a 1952 massey 44 and lately while using it i have trouble with ti jumping out of gear. it usually does it under load with the pto engaged. what would cause this. its first gear only
check lower post
07-24-2003 17:10:33
 Re: massey 44 1st gear in reply to Doug, 07-22-2003 19:48:36
Scroll down, about eleven posts, you may have your
answer. Post back, if needed.
mike
08-08-2003 16:20:19
 Re: Re: massey 44 1st gear in reply to check lower post, 07-24-2003 17:10:33
it was worked with it not in gear rite so the end of the gear is wore out so when it is under load it wants to pop out. its alot of work to fix it unless you have some important reason to, dont fix it
