444 live PTO
MH444LP
07-21-2003 19:22:23
Will the live PTO set-up from a 333 swap onto my 444? (The 444 does not currently have the setup)
Thanks in advance
off the land
07-23-2003 09:44:20
 Re: 444 live PTO in reply to MH444LP, 07-21-2003 19:22:23
Row crop to row crop, bolt for bolt, identical.
Better to use 333 parts, a lot less stress, how
is your input shaft, flange, keyway? Unless your
a purist on matching S/N's, bolting up the entire
333 transmission case, axle to axle, is less work than complete brake conversion/adjustment. Avoid
'Standard' to Row crop, pedals are different, you
have to modify. If the 333 case is sealed, not
rusted on the ground, pedals, lever, move well,
flange is snug, gear oil up, no pitted gears, change the cases. About half the labor, you get a
better drive train. Specials live PTO/disc brakes will work also. Good luck.
MH444LP
07-23-2003 11:08:49
 Re: Re: 444 live PTO in reply to off the land, 07-23-2003 09:44:20
Thanks for the reply. My 444 is a low hour tractor and in nice shape. I think I will just leave it as is in this case. I was hoping it might have been an external change. I was thinking of using it on my three point grooming mower and the "Live" PTO would not help much there anyway. (vs. Independent PTO) thanks again!
