MF 30/33? or a 44?
Potential Masse
07-19-2003 06:54:18
How can I tell the difference and find out what model this is? There is a casting date on the side of the transmission 2-22-52. Has 3 Pt hitch and PTO, although I don't know how to tell if it is live. Has live hydraulic pump on the front, w/ reservoir behind the grill. PTO is rather high up on back of tractor.
Any advice? (Where is model plate, and what should I look for?) Car dealer has, and told me it was a MD35. It is definately a Massey Harris though. It looks good, no leaks. Is $2900 too high for that?
Brad Gyde
07-19-2003 17:42:54
 Re: MF 30/33? or a 44? in reply to Potential Massey Owner, 07-19-2003 06:54:18
On the massey-harrises, pre triple series (333,444,555) the pto's were high on the rear ends. to tell if the pto is live, there should be a hand lever on the brake pedal side. If it is not there, no live pto. I am uncertain if 30's ever had 3 point. Another quick way to find out if it is a 30 or 33/44 is if the motor is a flathead. 33's and 44's (excluding 44-6's) has a valve in head engine.
as for the price, most of the old massey harrises in my area (se lower MI) matching the description stated would sell for $1,000-2,000, unless it is completely redone.
Hope this helps Brad
David B
07-19-2003 11:17:20
Not much information as to discription of the tractor. Is it a rowcrop tractor? Tractors made in 1952 were Massey Harris, red with yellow wheels or Ferguson wich were grey. The Massey Ferguson name wasn't used till maybe 1958 or 1959 and then were painted red tin work and wheels over grey engine, transmission and rear end housing.Most Massey's were made to climb up the back to get on the seat where the Ferguson or Massey Ferguson were mounted from the side in front of the wheel and you straddle the transmission case. If the hyd pump is engine mounted then it is a "live"system. M-H should have a model/serial plate on the side of frame ahead of clutch pedal. Also it is stamped on the top of trans case just aft of the pto/pulley shift lever. It should read 44G1RF for a 44 or 30G1RF for a 30. I think the 33 was introduced in 1953 and if it is a 33 the model number should begin with 33. The 30 has a flat head 4 cyl mptor and the 33 and 44 have overhead valves 4 cyl motors. It would have to be a real "cherry" to bring that kind of money unless it is a later M-F tractor. I don't know what a MD 35 is. Could mean a MF 35? You need to identify this tractor before you spend good money for it. There is a lot of the difference between the value of the later M-F utility type tractors and the older style M-H tractors if you are going to use them.
