165 Hydraulics
Jeff
07-18-2003 19:44:24
I just got a Massey 165. It has 2 hydraulic control levers. Can someone please explain how to propery use this setup, Thanks
Big Dean
07-19-2003 23:56:00
 Re: 165 Hydraulics in reply to Jeff, 07-18-2003 19:44:24
The control levers to the right of the seat on the quadrant are the outside one is the Draft Control Lever The Inside one is the Position Control lever. The Position Control lever is the one you normally use. The Draft Control lever has to be in the full up position to use the Position Control & the Position Control lever has to be in the transport position to use the Draft Control lever. Draft Control is used basically for plowing Email me & I will try to explain more about how the Draft works. The Position is used when you want to set the lift arm in any position between all the way down to all the way up. Hope this will help if you need further help Email me.
