PTO won't engage
Steve Smith
07-16-2003 20:49:31
I just finished doing a complete rebuild of a 64 MF35 w/perkins. Runs great but the PTO will not go into gear in the live position and it goes into the ground speed position but does not do anything. When I try to put it into live it just grinds. I replaced the clutch while I had it appart, drained the trans. fluid and changed the trans filter. Any ideas?
Norm35
07-17-2003 18:59:50
 Re: PTO won't engage in reply to Steve Smith, 07-16-2003 20:49:31
Hi, I would definitely verify the linkage where the small PTO handle engages. If it is not positioned properly it will act like you mention. You have to remove side cover and look closely how the handle connects to the interior levers.
And or as mentionned make sure your second stage clutch is operating properly by inspecting through the access hole below where tranny meets engine.
Good Luck
Norm in Ont.
ALAN
07-16-2003 21:21:34
Steve, It sounds like your 2nd stage clutch is not adjusted properly. We had a similar prob that turned out to be a sheared pivot pin for the pressure plate, but if you had it all apart, you would have seen that. If everything isn't adjusted JUST RIGHT you'll have a lot of problems. I'd suggest looking up the specs in the manual, and double check myself... Lord knows you'll be in good company if that's what happened. Good luck - ALAN
