Help on a 44RC
Lieas
07-12-2003 07:12:31
Last year this unit started running bad,like it was getting no fuel,then finnaly stopped running altogeather Had carb rebuilt-no help
Put fuel into all 4 cylinders-Starts right up add
stops
no air restrictions leading into carb
What could this be?
marlowe
07-12-2003 09:02:37
 Re: help on a 44RC in reply to Lieas, 07-12-2003 07:12:31
do you have real good fuel flow from tank to carb?it must be a full stream all the time pull out the tank fitting some have a screen in the tank
SHANNON
07-12-2003 19:31:27
 Re: Re: help on a 44RC in reply to marlowe , 07-12-2003 09:02:37
im pretty sure its the carb.if it starts right up with pouring gas into the intake and runs great then its gotta be the carb... i rebuilt that carb and it never would run right and keeps dying on me... so i took apart and cleaned out again once more those darn tiny holes that you can miss easily i cleaned those out and put it back on and it started right up real quick! i couldnt beleive it was the carb the whole time... good luck
