Plow draft control
Randy
07-11-2003 02:07:08
Folks: The old Fergies, and Ford-Fergusons used a spring that a plow's top link would push and pull on when in use to make the tractor's hydraulic system adjust the draft and depth due to ground conditions. My MF35 doesn't have that spring. Is it internal, or was it replaced by a seperate depth and draft lever, or do the older tractors have that lever or not? Thanks.
smokey
07-11-2003 18:04:36
 Re: Plow draft control in reply to Randy, 07-11-2003 02:07:08
Check Big Dean Austin's site. He has diagrams that explain it all - the spring is behind the top link covered by a rubber cover.
C. T. in Oklahoma
07-12-2003 11:51:24
 Re: Re: Plow draft control in reply to smokey, 07-11-2003 18:04:36
I was going to reply that my MF 35 didn't have a rubber covered spring, but since I am a fairly new tractor owner, thought I would look a little closer. Smokey, you nailed it. Your advice about Big Dean was good also. C. T.
