Massey 744PD Help!!!!!
Earl S.
07-09-2003 16:50:48
We need help to certify this tractor in ITPA.We need stock engine casting numbers for block and head,how to ID. the injection pump.The high speed throttle setting??? 2350rpm ???Is the stock engine P6-288 Perkins. We want him to be able to pull but it has to have correct engine.Thank you . Earl
R Bell
08-13-2003 20:19:31
 Re: Massey 744PD Help!!!!! in reply to Earl S., 07-09-2003 16:50:48
Need casting and serial numbers. Have pictures of 744 starter is on right hand side of tractor. I have seen starter is on left side. I believe engine to be a 354 or 372.
Thanks R Bell
Roy in UK
07-10-2003 11:45:35
The 744PD was indeed factory fitted with a Perkins P6-288
Does it say 744PD or 744D on the side? because if it says 744PD it means it is an early one. Apparently the first ones were built in Manchester, and later production moved to Kilmarnock, in Scotland.
