Rubber head light gaskets?
Mike D.
07-09-2003 12:23:25
Hi- I'm looking for those rubber head lamp rings that fit between the sealed beam and the metal head lamp bucket. Any ideas? I contacted NAPA and they thought I'd lost my mind. The head lamps are 4 1/2" and fit a M.H. 444 Thanks-
James, UK
07-10-2003 02:09:15
 Re: rubber head light gaskets? in reply to Mike D., 07-09-2003 12:23:25
Over here it is possible to buy 'O' ring repair kits - so you can make your own 'O' rings from round or square rubber strip cut to length and Loctited at the join - something like that would probably do the job for you.
DON L
07-09-2003 17:30:38
I have new ones.
off the land
07-09-2003 16:12:00
Got an old tractor tire inner tube, lying around?
You can try your luck cutting some strips of size
to stabilize the lens. Keep the seam to the bottom, to reduce water entering the can. Good luck.
