Is there a system to Marvel Schebler carb numbers?
Mike Wells
07-08-2003 20:55:47
Have seen carb numbers from TSX42 to TSX905. There doesn't seem to be any rhyme or reason to the number system. Please, someone shed some light on this mystery. thanks
Bill Hires
07-09-2003 04:57:02
 Re: Is there a system to Marvel Schebler carb numb in reply to Mike Wells, 07-08-2003 20:55:47
The TSX was manufactured in three sizes, 7/8", 1" and 11/4". In addition to these variations in size, there are also variations necessitated by the specific requirements of the engines on which they were used. Many engines required special throttle and choke operating levers and for purpose of calibratiopn they may have different size jets, nozzles, venturi, etc. Carburetors TSX-107, 330, 339, 355, 385, 398 use the fuel adjusting type nozzle, all others use the air adjusting type idle nozzle. The numbering system matches the carburetor to the specific engine requirements.
Alberta Mike
07-08-2003 21:14:22
Often wondered that same question. I know that I have bolted up any version of the MS carbs onto a number of tractors and they all seem to work equally well as long as the bolt-up holes match up to the manifold. One limiting factor is the linkages for the throttle and choke shafts but even those I have reversed by drilling out the castings. Looking forward to seeing if anyone knows.
