MF135 diesel fuel in oil
Sam from Jawja
07-06-2003 18:23:53
Seems like my 135 is manufacturing diesel oil, the level keeps growing but it sure is thin!
Seriously, I seem to be getting fuel in the oil pan. I've replaced the lift pump, thinking it was the most likely culprit, but after running it about 3 hours, the oil level grew by about 1/4 inch on the dipstick. Where is the next most likely place it could be coming from? The injection pump?
The tractor has about a billion hours on it, and smokes pretty good under heavy load, but other than that, it cranks every time and runs great.
Just looking for ideas on where to look next. I know someone here has had the same problem.
Thanks in advance for any replies.
Sam
Kraig
07-06-2003 22:51:55
 Re: MF135 diesel fuel in oil in reply to Sam from Jawja, 07-06-2003 18:23:53
Butterfly seals on the drive shaft of the injection pump. On a roosa master that is what they are called I imagine u have a CAV pump and it must be similar.
marlowe
07-06-2003 19:42:36
you got it!! injection punp seal on the main shaft
