Massy 44
Phil
07-06-2003 11:27:02
Last year It Run Like It Was Starving for gas and quit running
Rebult Carb New Points, Plugs Condensar Coil Plug Wires.Will Not Fire.Air Passage Open. Timing On.
What Do I look for next????
Allan C
07-06-2003 18:46:17
 Re: Massy 44 in reply to Phil, 07-06-2003 11:27:02
Well, ya gotta figure out if it's spark or fuel. Is there gas in the carb? Does it flow freely ou the line if you disconnect it from the carb?
Have an assistant crank the engine while you hold a plug wire near the block. You should get a spark 1/4 to 3/8 inch long. You're missing one or the other.
