Wide Rear Axle Unique?
off the land
07-04-2003 09:44:46
I looked at a MH 44 Special, with 114" axles.These
were an option, in '53-'55. Today, they seem like
an accident waiting to happen, when the rear rims are pushed in. They add about 30" of width to the 44. My plan was to restore, but I question leaving
the extended housing and axle shafts, as-is. The
S/N does not designate this added option. Would I
banish a unique option, by converting to the row
crop axle and housing? Difficult option to find,
but I don't view them as an asset to a restored antique tractor.Comments?
Alberta Mike
07-04-2003 20:18:20
 Re: Wide Rear Axle Unique? in reply to off the land, 07-04-2003 09:44:46
Hello Mike, what would that option have been for? Obviously, Massey thought they could sell it to someone who needed the extra width.
off the land
07-05-2003 10:14:04
 Re: Re: Wide Rear Axle Unique? in reply to Alberta Mike, 07-04-2003 20:18:20
Hello to you,Mike,
Fifty years ago, a fifty HP tractor would operate
hillside terrain with added safety, also row spacing of certain crops. Hub duals had not been
offered then, and power adjust six rail were just
appearing, though they would not have the range
of these. They have an awkward appearance, since
not adding to traditional 44 classic beauty. I'm
searching for a good reason to keep them, but at
this point, no one has defended non-function 50's
option, in 2003 restoration. Opinions?
Alberta Mike
07-05-2003 12:02:29
 Re: Re: Re: Wide Rear Axle Unique? in reply to off the land, 07-05-2003 10:14:04
If storage space wasn't a problem, I would certainly keep the wide set ups, for sure you'd be the only guy around with them. Trailering would maybe be a problem if you were backing onto a trailer rear wheels first. Maybe with a wide adjustable front end (almost unheard of up here) the wide rearend wouldn't look so strange but with a narrow front I could see it looking a bit odd. Did you buy the tractor or are you just considering it?
off the land
07-05-2003 17:23:22
 Re: Re: Re: Re: Wide Rear Axle Unique? in reply to Alberta Mike, 07-05-2003 12:02:29
The danger issue is when the wheels are pushed in, to appear better, the axle shafts stick out
about 10 or 12". Someone looking at the'nice red'
old tractor, can drop to the floor walking into
the surprise axle shaft. Driving it around can reduce the jogging population, on narrow roads.
If going back to the field, these would not be
issues, but the field work is over. Decisions...
