MF50 Auxillary cylinder control valve ?
Steve
07-03-2003 20:14:57
Hi, I installed a double control valve on top of my lift cover, but I don't know if it works right. It is supposed to let me use my position control and draft levers as normal , Right? But since I put it on the 3 point won't lift or lower unless I move one of the levers in or out. Does any one know the proper way this is supposed to work so I know If the valve is in need of attention, or am I the one that needs attention!! Thanks in advance. Perplexed
Big Dean
07-04-2003 09:13:53
 Re: MF50 Auxillary cylinder control valve ? in reply to Steve, 07-03-2003 20:14:57
Hi Steve
Your valve is working like they are supposed to I have some information on how these work & how to use them if you will send me an Email address I will send it to you.
Steve
07-04-2003 15:33:22
 Re: Re: MF50 Auxillary cylinder control valve ? in reply to Big Dean, 07-04-2003 09:13:53
Thanks alot for the info. I am glad that I am the one short on operating instead of something broke. I gave you my e-mail @ your web sight.
Phil A.
07-04-2003 09:06:53
Move the left auxiliary valve lever to the rear and leave it there. The 3 pt position control and draft control levers will then work normally.
Steve
07-04-2003 15:35:51
 Re: Re: MF50 Auxillary cylinder control valve ? in reply to Phil A., 07-04-2003 09:06:53
Thanks alot for the info. My three point does work normally when I move the lever as you said.
