GOOD DEAL OR NOT, ON A MF 50 W LOADER/HOE
glenn
02-17-2000 12:35:44
Im thinking of buying a 50a with loader and extend a hoe,two buckets.Motor smokes very
bad out breather.Been run without air cleaner
for years.Is in fair shape,but motor is bad.
Is it worth $2,000.00??? and how much should i exspect to pay to rebuild motor{parts vs labor}
3cly pekins or continental??? thanks for any imput. GLENN
rod
02-17-2000 13:33:15
 Re: GOOD DEAL OR NOT, ON A MF 50 W LOADER/HOE in reply to glenn, 02-17-2000 12:35:44
What is condition of hyd pump slow or fast, leaks, trans work ok pins and bushings all ok gen condition cracks in frame etc can soon run into lots of money if you can't fix yourself basically you are buying a salvage job so try to beat prices as low as you can. I was once in a bidding war on a mf 50 it sold for 3500.00 can and leaked fluid everywhere and hyd pump was weak and tires bald go figure.
rod
