Skirted thermostat
David UK
07-02-2003 13:41:13
Can anyone clarify what thermostat is correct for the Perkins 3.152 engine series (normal or skirted type) and explain how the bypass circuit actually works. I have just done an engine swap and one engine had a skirted thermostat in it while the other didn't. I suspect skirted type is original. I can't see how it does anything other than block the flow via the bypass entirely when engine is cold which is when I thought the bypass was supposed to be open - if you understand what I'm getting at.
