Arc in pionts
seth or carole
06-27-2003 21:14:53
need help my points arc on the distibutor jumping all over need some hints can the condenser be bad also what is the easiest
way to time a perkin 3 clynder thank you
Allan C
07-01-2003 22:47:37
 Re: arc in pionts in reply to seth or carole adams, 06-27-2003 21:14:53
Yes, the condenser can definitely cause this. A bad one also causes very poor starting and running, but you will usually find a fairly good spark when you test it, but it will be intermittent, or will spark once, then quit. I have also seen a bad set of points arc at the pivot (rare) or, is it a 6 to 12 conversion? if so you need a resistor in the power wire to the coil.
