Pony Questions
Darwyn
06-27-2003 17:19:50
Ran a Pony years ago with a mower on twp roads. Just bought one in good shape and have a few questions:
- what grease is used in the transmission?
- SAE 30 engine oil?
- where do I find the serial number / year?
- is hooked up with -ve ground. I thought these
were +ve ground?
I will have to track down manuals.
Thanks.
Pike111
07-03-2003 04:11:50
 Re: Pony Questions in reply to Darwyn, 06-27-2003 17:19:50
The Pony transmission does take regular #90 transmission oil. The electrical is a positive ground. I have original original manuals. If you are interested, just email me. Good luck.
Larry Renaldi
06-29-2003 16:05:58
Darwyn it is 6 volt + ground and I forgot to not block my email addee ! Larry
Larry Renaldi
06-29-2003 16:00:41
Hello Darwyn The Pony is supposed to have 30 weight oil in the engine and hydraulic system ! Let me check ,but I think the rear end/trans is supposed to have 85/90 W gear oil ! The ser.# is located on the right side as you sit in the drivers seat below the engine ,on frame ! Email if you have any further questions ! Larry Renaldi
