IPTO slipping..Big Dean ?
Joe Ferguson
06-26-2003 18:37:44
Hi
The IPTO slips on my MF-135
I use the pto with the rototiller only
the rototiller has a neutral/engaged control
If I let the cluth slip for long period
will it hoverheat and stick the clutch disks
together and cause IPTO to run all the time ?
Thanks in advance
Joe Ferguson
Joe Ferguson question -2-
06-26-2003 21:31:02
 Re: IPTO slipping..Big Dean ? in reply to Joe Ferguson, 06-26-2003 18:37:44
Condt
On the side cover which support the IPTO lever
there are 2 holes the upper hole is (I think)
the pressure test port or auxiliary pressure port.
3 inch lower there is a hole with no treads inside
previous owner put a carriage bolt loose in the hole. As per a photo in service manual there is a kind of lever or fork behind the plate which faces
directly the hole..do you know what is the purpose
of this hole/pin/fork.
Many thanks
Joe Ferguson
