MF 65
Trevor
06-26-2003 18:19:00
our mf 65 keeps burning out starters like we have to replace them atleast every year or a little more, whats the cause?
Big Dean
06-28-2003 10:12:01
 Re: MF 65 in reply to Trevor, 06-26-2003 18:19:00
The things that normally cause that problem is either cranking one to long at a time causing the starter to over heat or bad connections especially the ground cable it is best to have the ground cable connected to the block someplace. or to light of cables good cables are a must especially on the diesel engine. if I can be of further help Email me
dean(not big Dean)
07-02-2003 10:08:03
 Re: Re: MF 65 in reply to Big Dean, 06-28-2003 10:12:01
I found on my MF65 diesel that the battery I bought at TSC did not have enough cranking amps. The guys at MF told me to get at least 650 amps and my problem was solved. It now starts without smoking up the starter.
