MF250
Eddie
06-24-2003 13:44:39
I've been assigned the job of getting a MF250 that's been under water running. I plan on removing the Fuel tank to drain, changing fuel filters, removing injectors before turning over to prevent the possibility of hydro lock, draining oil, change oil filter, change hydraulic fluid, and changing power steering fluid, and changing both inner and outer air filter.
Is there anything I'm missing? Does anyone have a manuel that gives the oil and hydraulic fluid capacity?
Thanks
tortmort
06-25-2003 19:31:45
 Re: MF250 in reply to Eddie, 06-24-2003 13:44:39
Oil 7.2 quarts with filter 6.2 without
Trans/Diff/Hyd 11 Gallons
Power Steering 1 Quart
Steering Box 1 quart
Rear Axle 1.5 quarts
Eddie
06-26-2003 04:06:07
 Re: Re: MF250 in reply to tortmort, 06-25-2003 19:31:45
Thanks, That's what I needed to know.
