Need 1080 help/opinions
Dan
02-16-2000 17:06:49
Are these good tractors? We used to farm with one 15 years ago and liked it. Now looking to buy. Found 1 but has steering problems (nothing happens cold and very little when hot). Other than that it is in good condition. What should I look for etc. Thanks for any help!
Merle
02-19-2000 09:54:25
 Re: Need 1080 help/opinions in reply to Dan, 02-16-2000 17:06:49
Dan Look at the rear planitary gear seals for oil leakage. I have ran/owned a 1080,1130,1155 and each have their good and bad points. email me if you have a specific question. Good Luck
Merle
Mike
07-27-2000 16:18:12
 Re: Re: Need 1080 help/opinions in reply to Merle, 02-19-2000 09:54:25
Tom from Ontario,
Do you have any leads still on a MF 98?
970/679-5549
Merle
02-19-2000 09:54:13
Merle
Johan Storg�rds
05-28-2001 05:40:23
 Re: Re: Need 1080 help/opinions in reply to Merle, 02-19-2000 09:54:13
Hello,
I'm thinking of buying one. The motor and hydraulics seem to be ok, but there is a lot of noise from the gearbox, when I'm reversing. It sounds like the oil-level is too low. Is this normal? Should I expect costly repair?
Bob
02-19-2000 09:40:20
I had both a 1080 and a 1130.The 1080 is a good tractor but the 1100 series tractor are a lot nicer to use. They have hydraulic brakes, hydrostic steering, and superior three point hitch and remotes.
Sid Miller
02-18-2000 09:34:36
Dan,I happen to have a 1080.It have used it to pull a 5 bottom plow,15 foot batwing mower, and a 2 row corn chopper.The tractor is rugged and reliable if maintained properly.It is comparable to my neighbor's 1100.The steering and the lift are potential trouble spots though.There is a valve underneath the seat that sticks and the lift will not raise.However,the valve is easily unstuck and is no problem if the tractor is used frequently.
Ernie D
02-17-2000 17:23:13
Neighbor had one. It was a dog compared to a 1100 pulling. My brother had a used 1100, very expensive parts.
