TO-30 Coolant in the Oil
Colonel
02-16-2000 16:29:05
What would cause antifreeze to seep into the crankcase oil? Bad water pump? Head gasket? Can you retorque the head bolts and hope that it solves the problem? Where do you look first? Any advice is most welcome. Thanks.
Paul
02-16-2000 17:28:49
 Re: TO-30 Coolant in the Oil in reply to Colonel, 02-16-2000 16:29:05
Colonel - the Continental Z129 engine in the TO-30 was notorious for developing cracks in the block between the cylinders. If you were to pull the head, you could observe whether or not there are cracks. You might also pull the pan and, with a good light, look up and see if you can see any cracks in the block extending down the cylinder walls. The "o" rings for the sleeves could also be bad. Yes, it could come from a bad gasket, but that is less likely. If there are cracks, and they are not too bad, the block can be repaired.
Paul
Ernie D
02-17-2000 17:20:46
 Re: Re: TO-30 Coolant in the Oil in reply to Paul, 02-16-2000 17:28:49
We had one that overheated and warped the head. Milled head flat and it was fine.
