Torque specs
Randy
06-22-2003 03:44:46
Folks: How tight should the axle bolts be torqued to when the front end has been apart to narrow down the front track? I put in 4 new grade 8 bolts and nuts (the originals were grade 5 according to the bolt head markings). The tractor is an MF 35. Thanks.
Arthur Blackwell
06-22-2003 05:00:38
 Re: Torque specs in reply to Randy, 06-22-2003 03:44:46
Hi there Randy
found this info that you requested plus some more.
1. centres to right hand and left hand axles Specified Torque 90 to 100 Yield Torque 130+
2. Spindle arm Specified Torque 50 to 55 Yield Torque 65
3. Spindle Yield Torque 130+
4. Radius rod-axle Specified Torque 90 to 100 Yield Torque 130+ 5. Clamp steering drag link Specified Torque 6 to 8 Yield Torque 20
cheers Arthur from Tasmania
Randy
06-23-2003 05:31:16
 Re: Re: Torque specs in reply to Arthur Blackwell, 06-22-2003 05:00:38
OK Thanks.
