MF 240 Pwr steering cyclinders
David
06-15-2003 19:55:50
Need pwr steering cyclinders or re-build kits for the cylinders going to each front wheel. Anyone ever rebuid them? Cannot find any part numbers or either one. Ball joints are not repairable, must replace entire assembly if ball joint is bad.
Thanks, David
ray-s
06-16-2003 08:33:22
 Re: MF 240 Pwr steering cyclinders in reply to David, 06-15-2003 19:55:50
Link
Have you looked at the cylinders at the above site. No prices shown.?
carl
06-16-2003 17:28:00
 Re: Re: MF 240 Pwr steering cyclinders in reply to ray-s, 06-16-2003 08:33:22
i have massey mf40b industrial tractor that i had my clylinders reworked by hydraulic shop after getting the parts from pittsburgh tractor in pittsburgh tx, they are very helpful have a web site and 800 number, also they salvage out only massey and kubota the two lines they carry new, give them a try
Davidr
06-17-2003 19:55:01
 Re: Re: Re: MF 240 Pwr steering cyclinders in reply to carl, 06-16-2003 17:28:00
Carl, could I please have the web site and/or the 800 number for the tractor parts store which you mentioned in Pittsburgh, Tx. Could not locate by internet search. Thanks, David
David
06-16-2003 11:37:32
Thanks for the information from both replies. I knew that the cyclinders would be expensive but no idea they would be that much. The one shown at bare-co is not the one on my MF240. Mine has only one ball joint and the other end is a solid pin that attaches to the axle(?), then has the fluid lines going into it near that attachment point. Attempt to order rebuild kits from local MF dealer were negative. State they cannot order kit without a number from the cyclinder. No numbers anywhere on either cyclinder. I attempted a repair with generic "O" rings but that did'nt work either. Guess I'll just have no pwr steering. Thanks, David
Cash Moline
12-15-2003 18:12:15
 Re: Re: Re: MF 240 Pwr steering cyclinders in reply to David, 06-16-2003 11:37:32
David, Here is the Pittsburg info and website.
Pittsburg Tractor, Inc.
1893 State Highway 271 North
Pittsburg, TX 75686
www.pittsburgtractor.com
*no H in Pittsburg
Phone: (903) 856-6548
KC
06-19-2003 10:45:19
Change Dealers, they sound clueless and/or inept. Take the cylinder(s) with you, maybe they can pull a number. Pittsburg Tractor used to advertise in Farm Journal classifieds a few years ago, had a toll free number.
kjm
06-16-2003 19:00:22
David try a local Hyd. Shop, my phone book lists two and we are only 40,000 pop.
06-16-2003 06:20:35
David, I just got one fixed for an MF 245, only one cylinder. The dealer rebuilt the cylinder only, about $75. Here's the good part, I called at least 20 parts houses all across US and NONE carried a rebuilt one, nobody rebuilds them. A complete cylinder from MF is about $580. To replace the shaft only, MF wants only $280. Can you smell your wallet burning? MF is making a killing off of an extremely poor design and no aftermarket companies are making their own to sell. Good Luck!
