WANTED WIDE FRONT FOR MASSEY H ARRIS 44
SHANNON BONE
06-14-2003 08:28:10
NEED A GOOD WORKING WIDE FRONT FOR MASSEY HARRIS 44.... WILLING TO PAY UP TO $275.. DEPENDS.. IF YOU HAVE IT...EMAIL ME THANKS MR SHANNON BONE
SHANNON BONE
06-14-2003 19:42:29
 Re: WANTED WIDE FRONT FOR MASSEY H ARRIS 44 in reply to SHANNON BONE, 06-14-2003 08:28:10
opps i wasnt supposed to post this messages on that discussion board.. my mistake... i have narrow front , wanted to change into wide front so i have found one for that price and someone already got it before i got it.. and saw one on ebay sold at around $300 so i thought thats the normally range price for the wide front assembly dont you think? so far i have seen them run around 200 to 400 at most... so anyways thanks
shannon
I want to know ?
06-14-2003 15:33:58
What kind of a 'good' wide front you can get for 'up to $275.00' ?
off the land
06-14-2003 16:09:52
 Re: Re: WANTED WIDE FRONT FOR MASSEY H ARRIS 44 in reply to I want to know ?, 06-14-2003 15:33:58
Yes, every Wide Front End needs at least $275. in rebuilding. You can add six thrust washers to any
sector gear. The reverse steer worm shaft is very
rare. Bushings, bearings, wedges,tie rod ends,
welding ovaled holes, new stops,cap the wedge holes. How much wear on tooth 3 & 4 of the sector
gear?Rebuild the steering box,who has a backlash?
Unless you cut gears, play remains. WFE's tend to
wear,don't get enough grease. To secure the old
steering box,you need longer bolts,lock nuts. You
have to do the job right, so do it yourself.
Just wondering
06-14-2003 14:24:43
Those darned classifieds keep sneaking over into the discussion forum. Wonder how that happens even after we're kindly reminded not to post ads here? Maybe an electronic glitch?
