MF202 clutch setting
Iowa Dave
06-12-2003 16:03:10
Anyone know the procedure for setting clutch release lever adj. bolt height for a Spicer dual clutch on a 1962 MF202 w/ Continental Z134 engine?
My manuals address the procedure for early and late model Auburn clutches. The late model looks like my Spicer, but the gage for setting the height (Which I had made according to the manual specs) doesn't fit, even with the bolt screwed all the way in.
I have a pretty late serial # tractor, did they go to a Spicer clutch on late models or is it more likely it's just been replaced at some point?
Big Dean
06-12-2003 21:35:35
 Re: MF202 clutch setting in reply to Iowa Dave, 06-12-2003 16:03:10
Through the years there has been several different replacement pressure plate assembly used on the clutches in the Massey Ferguson tractors. There are at least 5 different tools for setting the finger height on them. I have a picture that shows how to set them when you don't have the proper tool for the pressure plate assembly yours has. If you will send me an Email address I will send it to you
Iowadave
06-15-2003 22:23:10
 Re: Re: MF202 clutch setting in reply to Big Dean, 06-12-2003 21:35:35
Thanks, Dean, for the photo/procedures on the clutch setting and for the instructions on splitting/assembling on your web site. You're right: the equalizer bar is a must. Sure is a good feeling when those splines clunk together. Gotta go back to the army tomorrow, will be a month and a half before I get back to her. I'll let you know how the clutch settings come out.
