Mf 135
vern, tx
06-11-2003 22:29:02
what is the diff in 135 special and 135 deluxe models.
Richard in Id
06-13-2003 21:46:17
 Re: mf 135 in reply to vern, tx, 06-11-2003 22:29:02
Vern, according to my operators manual, the 135 deluxe has differential lock, has 3 pto positions(proportional engine speed, neutral, ground speed) has full instrumentation(water,fuel,amp,oil pressure guages and tachometer all illuminated. The Special has 2 pto positions (engine pto and neutral) Has only 2 guages (oil presssure and water temp and not illuminated. Don't know if only the deluxe model came with power steering. I believe these are the main differences, at least to my knowledge.
vern duty
06-14-2003 16:30:42
 Re: Re: mf 135 in reply to Richard in Id, 06-13-2003 21:46:17
Mine must be a deluxe because i have the diff lock and all the gauges. Mine also has the power steering but it has never worked very well. I heard these tractors had problems with the powersteering Thanks alot Richard
David
06-12-2003 12:51:32
I've no idea but as a follow on to the FE35 question below it will be interesting to find out! A natural progression you might say. Good question.
