Help ID Continental Motor
Jim B.
06-08-2003 18:11:19
Help! I have a flathead Continental, Block casting # F400A - 618 (or maybe 613). Head Casting # 4E23. Governor located front lower right in attached housing. Has a gasket set part # F4U01007 with it.No data tag on engine. Any Ideas what it is or how much more it'll take to ID this thing? I could remove the oil pan and measure the cyl/stroke, but as a last resort. Any help greatly appreciated- tell me what to look for! Thanks.
Alberta Mike
06-09-2003 11:41:41
 Re: Help ID Continental Motor in reply to Jim B., 06-08-2003 18:11:19
That casting number was the same I think for all of the 4 cylinder flathead sizes (which were 124, 140, and 162 cubic inches). On the left side of the engine block there is a place for a tin plate (rectangular) but it is probably gone, it would've had the size on it. Above the front frost plug just below the cylinder head is another raised part in the casting which has been machined flat and there might be a hand-stamped number into that area showing engine size. If you don't need to take off the head then you should keep it on. Knowing the engine size won't help anything, all parts, etc. are the same (other than the rings and pistons and cylinder bore size).
Jim B.
06-09-2003 15:49:17
 Re: Re: Help ID Continental Motor in reply to Alberta Mike, 06-09-2003 11:41:41
Thanx Mike- I'll check for more numbers and reply. So if I've got this right, the F400 block is one of the previous displacements you posted, then the only other differences would be compression,cam, carburator and brackets.
Alberta Mike
06-09-2003 16:29:20
 Re: Re: Re: Help ID Continental Motor in reply to Jim B., 06-09-2003 15:49:17
That would be about it I'd say, the block is definitely the same one. I bolted down a head from a 140 onto a 124 a few years ago and it worked perfect. And yes, I think there might have been some of the differences you noted and also I think some might have had the governor where others had the factory hydraulic pump (facing the back of the tractor).
Jim B.
06-11-2003 02:53:50
 Re: Re: Re: Re: Help ID Continental Motor in reply to Alberta Mike, 06-09-2003 16:29:20
Found the #'s, Block stamps: NB 8-83 WT 8377 S/N 132.
On machined spot on head: F401A602. Block casting : F400A613. Head Casting: 4E23. Maybe these mean something to someone in the know.
Alberta Mike
06-11-2003 04:03:05
 Re: Re: Re: Re: Re: Help ID Continental Motor in reply to Jim B., 06-11-2003 02:53:50
IS that F401 or F140 at the start of that one number?
Jim B.
06-11-2003 15:52:54
 Re: Re: Re: Re: Re: Re: Help ID Continental Motor in reply to Alberta Mike, 06-11-2003 04:03:05
Hi Mike, yes, stamped on the machined spot on head: F401A602. Cast on head 4E23 just below firing order 1342. Stamped on machined spot on block NB 8-83 and next line below that WT8377 S/N 132.Cast on block F400A613. I thought it possible that the stamps on block were a rebuilders mark as they don't match the head and they are quite uneven in placement and depth. So far no-one has been able to even say for sure it's a Continental. The gasket set does match up though. Thanks, Jim B.
Alberta Mike
06-11-2003 18:06:17
 Re: Re: Re: Re: Re: Re: Re: Help ID Continental Mo in reply to Jim B., 06-11-2003 15:52:54
No doubt it is a Continental, that I'd bet on. Below that cast-in F400 number (lower on the side of the block in that area) should be a symbol which is actually 3 letters intertwined ... a C and an E and an L if I remember correctly. Stands for Continental Engine Limited. That should be there I'm pretty sure.
Jim B.
06-12-2003 15:32:45
 Re: Re: Re: Re: Re: Re: Re: Re: Help ID Continenta in reply to Alberta Mike, 06-11-2003 18:06:17
Greetings and good news Mike from Alberta, I finally spoke with someone who knew someone who about 3 more times and got some info and a phone #. Here it is- Towmotor engine, Part# 8N2606. Continental F163, Propane. Parts Available, as are reman engines. ($2100.00) ($1900.00 core charge). Now the hard part, I need to find Accessories for this one, Manifolds, Carb, Distributor,Starter, Flywheel, Pulleys and brackets. Then I'll know if I will keep it or sell it. Many thanks for all your help pointing me towards the answers. Jim B.
Jim B.
06-11-2003 18:44:01
I'll look again, don't remember anything like that. BTW I'm in USA. Thanks.
