Want to add hydraulic remotes to massey 50
Jon in OHIO
06-08-2003 14:40:23
have a massey 50.it has no remotes .want use with my 477 n.h. haybine .how do i add on to tractor?how much will cost.will they be better than the lift on my50. had rebuilt and are still weak.
Bill
06-09-2003 18:25:16
 Re: want to add hydraulic remotes to massey 50 in reply to Jon in OHIO, 06-08-2003 14:40:23
I think you can add a pump to the front of the tractor that is driven off the shaft coming out of the engine that has the belt pulleys driven from it. I have read Big Dean say that with the 65's you have to modify one of the steering tie rods for everything to work together without hitting. I am not sure about the 50's. Otherwise you can remove the transfer plate on the top right of your tractor - under the seat and add one there. It will, however, be slow - but may be enough for your needs.
