MF 180 Steering Problem
David
06-08-2003 12:14:22
I just moved out to the country and along with
the place came a MF180 diesel tractor. I got it
running and everything works properly except for
the steering. The wheel will spin around freely
but there is no response, no noise, no nothing
from the front end. Steering pump has fluid in
it and all the lines are connected and tight.
Anyone have any thoughts or experience with this?
Thank you.
Big Dean
06-08-2003 21:45:37
 Re: MF 180 Steering Problem in reply to David, 06-08-2003 12:14:22
It sounds like either one of the piston seals in the unit behind the grill is bypassing or your steering system has air in it. To bleed the air out of the power steering system. You always fill the reservoir with the engine running on the diesel engine. After you have it full, turn the wheels from stop to stop several times to disperse the air from the system. You may have to fill the reservoir a couple of times if there is a lot of air in the system. You leave the plug out while you are bleeding the air out on the diesel engines.
